nobaloney
You shouldn't be using the System Backup unless you're an experienced System Administrator. Even then you may not want to use it. It backs up everything you need but it doesn't restore automatically. That said, if you're restoring to the same OS Distribution level just copying over the files/directories should work.But it lacks the backup function, and then i mean the restore system ofcourse...
What if an server crashes and you have only the system backup..
GOOD LUCK![]()
Which is how the Admin Reseller Backup works.Better they first fix the ultimate restore option..
Like hdd broke? replace hdd, plain install os, restore system backup and its running again..
Why aren't you using the Admin Reseller Backup?Now it will take hours to restore an server..
