- Feb 27, 2003
Version: 0.5
Due to numerous requests for it, I've taken the Email Level plugin for DirectAdmin, and turned it into a Squirrelmail Plugin.
The plugins has the same functionality as the DirectAdmin plugin.
- Shows the account usage, including the breakdown on the left, below the IMAP boxes.
- Link for "Change Password", and automatically updates the SM session password, so you don't get booted out after changing it.
- Link for "Vacation Message", allowing you to set, update and delete your vacation message through Squirrelmail.
Keep in mind I've never created a Squirrelmail plugin before, so forgive me if I didn't follow any of their rules for creating plugins (just let me know if you spot any violations).
Please don't email us about this plugin, it's provided "as-is", keep all discussion in this thread.
Do not submit this to www.squirrelmail.org. If and when it's time to do so, we'll do it.
If you wish to give the plugin a test drive, run the following:
Type 8 for Plugins.
Type in the number listed beside "directadmin", press enter.
Press Q to quit, and save the config.php (Y)
If you've got DA running in SSL, you'll need to tell the plugin, edit:
/var/www/html/squirrelmail/plugins/directadmin/include/config.php
set:
$da_ssl=true;
same idea for the $da_port value if needed.
If you update your version of SquirrelMail, you'll have to install this again.
Enjoy
Version: 0.5
cd /var/www/html/squirrelmail/plugins
wget http://files.directadmin.com/services/all/squirrelmail_plugin/directadmin-0.5.tar.gz
tar xvzf directadmin-0.5.tar.gz
chown -R webapps:webapps directadmin
cd ../config
./conf.pl
set:
$da_ssl=true;
Enjoy
