host: isc_socket_create: not enough free resources socket.c:2117: REQUIRE(maxfd <= (i
PRB
I used to have alot of these errors:
host: isc_socket_create: not enough free resources socket.c:2117: REQUIRE(maxfd <= (int)1024) failed.
So I found this tutorial: http://www.directadmin.com/help/item.php?id=9
so I ran these commands:
HTML:
cd /usr/local/directadmin/data/templates
cp virtual_host*.conf custom
cd custom
perl -pi -e 's/Error/#Error/' virtual_host*.conf
perl -pi -e 's/CustomLog/#CustomLog/' virtual_host*.conf
I no longer have those errors, but now the following problems occur:
1) Apache bandwidth isnt updated anymore, my users have had the same bandwidth for like 3-4 days now (thats how many days ago I ran above commands)
2) webalizer doesnt update any more
can someone help me please?
I might also add that I changed the loglevel to crit in httpd.conf. Is the problem because of that?
I suspect its because of the commands above. Should I undo something?
my etc/cron.d/directadmin_cron file:
* * * * * root /usr/local/directadmin/dataskq
2 0-23/6 * * * root echo 'action=vacation&value=all' >> /usr/local/directadmin/data/task.queue;
#5 5 * * 0 root /sbin/quotaoff -a; /sbin/quotacheck -augm; /sbin/quotaon -a;
10 0 * * * root echo 'action=tally&value=all' >> /usr/local/directadmin/data/task.queue
20 4 1 * * root echo 'action=reset&value=all' >> /usr/local/directadmin/data/task.queue
0 4 * * * root echo 'action=check&value=license' >> /usr/local/directadmin/data/task.queue
0 * * * * root echo '/etc/init.d/ntpd stop; ntpdate pool.ntp.org; /etc/init.d/ntpd start;' >> /usr/local/directadmin/data/task.queue
15 * * * * root echo '/etc/init.d/ntpd stop; ntpdate pool.ntp.org; /etc/init.d/ntpd start;' >> /usr/local/directadmin/data/task.queue
30 * * * * root echo '/etc/init.d/ntpd stop; ntpdate pool.ntp.org; /etc/init.d/ntpd start;' >> /usr/local/directadmin/data/task.queue
45 * * * * root echo '/etc/init.d/ntpd stop; ntpdate pool.ntp.org; /etc/init.d/ntpd start;' >> /usr/local/directadmin/data/task.queue
HTML:
cd custom
Well I'm going to guess that the way DA calculates data usage and webstats is through the customlog. Re-enabling it may be a good idea.
