Solution for: Imap support in php
demz
Holland, Den Haag
Trying to add --with-imap to your configure.php5 ?
and getting this error?
configure: error: utf8_mime2text() has new signature, but U8T_CANONICAL is missing
Solution (worked for me, this was a dovecot machine):
1. yum install libc-client
2. yum install libc-client-devel
3. add:
--with-imap=/usr/lib/dovecot/imap \
--with-imap-ssl \
to: configure.php5 (custombuild/configure/ap2/)
4. ./build php y
Tada!
Thanx for the tutorial but I'm having this problem with my CentOS 5.2 server.
After following your directions, at the end of the compiling, I get this error:
/usr/local/directadmin/custombuild/configure/ap2/configure.php5: line 31: --with-imap=/usr/lib/dovecot/imap: No such file or directory
*** There was an error while trying to configure php. Check the configure/ap2/configure.php5 file
The /usr/lib/dovecot/imap directory does exist.
That means you do not have dovecot installed. To use the above method you have to convert to dovecot first.
I have the same problem:
/usr/local/directadmin/custombuild/configure/ap2/configure.php5: line 31: --with -imap=/usr/lib/dovecot/imap: No existe el fichero o el directorio
*** There was an error while trying to configure php. Check the configure/ap2/co nfigure.php5 file
I have dovecot installed in the server:
[root@server custombuild]# cd /usr/lib/dovecot/
[root@server dovecot]# ls
auth lib10_quota_plugin.la lib20_expire_plugin.so lib20_zlib_plugin.a
imap lib10_quota_plugin.so lib20_fts_plugin.a lib20_zlib_plugin.la
lda lib11_trash_plugin.a lib20_fts_plugin.la lib20_zlib_plugin.so
lib01_acl_plugin.a lib11_trash_plugin.la lib20_fts_plugin.so lib21_fts_squat_plugin.a
lib01_acl_plugin.la lib11_trash_plugin.so lib20_mail_log_plugin.a lib21_fts_squat_plugin.la
lib01_acl_plugin.so lib20_convert_plugin.a lib20_mail_log_plugin.la lib21_fts_squat_plugin.so
lib02_lazy_expunge_plugin.a lib20_convert_plugin.la lib20_mail_log_plugin.so pop3
lib02_lazy_expunge_plugin.la lib20_convert_plugin.so lib20_mbox_snarf_plugin.a
lib02_lazy_expunge_plugin.so lib20_expire_plugin.a lib20_mbox_snarf_plugin.la
lib10_quota_plugin.a lib20_expire_plugin.la lib20_mbox_snarf_plugin.so
[root@server dovecot]# cd imap
[root@server imap]# ls
lib01_acl_plugin.so lib11_imap_quota_plugin.la lib20_expire_plugin.so lib20_zlib_plugin.so
lib02_lazy_expunge_plugin.so lib11_imap_quota_plugin.so lib20_fts_plugin.so lib21_fts_squat_plugin.so
lib10_quota_plugin.so lib11_trash_plugin.so lib20_mail_log_plugin.so
lib11_imap_quota_plugin.a lib20_convert_plugin.so lib20_mbox_snarf_plugin.so
Any tip???
same prob :(
Check './configure --help' for available options
/usr/local/directadmin/customapache/configure.php_ap2: --with-imap=/usr/local/imap-2007e: not found
*** There was an error while trying to configure php. Check the configure.php file
# updatedb
# locate imap-2007e
/usr/local/imap-2007e/tools
/usr/local/imap-2007e/tools/Makefile
/usr/local/imap-2007e/tools/an
/usr/local/imap-2007e/tools/ua
/usr/local/imap-2007e/tools/uahelper.c
Does anyone already got a solution for this? Because it seems it is not only in Custombuild, because im using Customapache.
(I came here trough search function)
I'm getting the following error:
configure: error: Cannot find rfc822.h. Please check your c-client installation.
server:/usr/local/directadmin/custombuild#
EDIT:
Lol my mistake! i didn't have libc-client-dev package installed! Damn i need some rest! (Debian 5 here, now testing the build ;) )
EDIT:
Unfortunately Imap extension didn't appear on phpinfo() :(
IMAP-2004c1 support i386
                yum install krb5-devel libc-client libc-client-devel -y
                wget http://dave.t0xic.nl/tars/imapback-2004c1-x86.tar.gz
                tar xzf imapback-2004c1-x86.tar.gz
                cd imap-2004c1
                ./buildit
                cd c-client
                mkdir /usr/local/imap-2004c1/
                mkdir /usr/local/imap-2004c1/lib
                mkdir /usr/local/imap-2004c1/include
                cp *.h /usr/local/imap-2004c1/include
                cp *.c /usr/local/imap-2004c1/lib
                cp c-client.a /usr/local/imap-2004c1/lib
                ln -s /usr/local/imap-2004c1/c-client.a /usr/local/imap-2004c1/libc-client.a
IMAP-2004c1 support x86_64
                wget http://dave.t0xic.nl/tars/imapback-2004c1-x86_64.tar.gz
                tar xzf imapback-2004c1-x86_64.tar.gz
                cd imap-2004c1
                ./buildit
                cd c-client
Worked perfectly on centos 5.3 by following steps in the 1st. post.
Needed it badly for WHMCS ticketing import...didn't seem to get email piping to work, so this certainly helps!
i came up with the /usr/local/directadmin/custombuild/configure/ap2/configure.php5: line 31: --with-imap=/usr/lib/dovecot/imap: No such file or directory
make sure that when you add the line to the configure.php5 that you add a \ to the end of the line above it..
eg --enable-mbstring becomes
--enable-mbstring \
then save and call the build command....
--enable-mbstring \
That was it! Thank you very much. :D
I have noticed that the imap module is named 2004, 2005 and sometimes 2007.
Does this mean that the 2007 versions i 2 years old?
EDIT: I checked it out, the 2007e version is from december 2008, and i have the 2007a version, that is from beginning of 2008. So, i guess i might need to upgrade it :)
Thank you very much!!
After so many days of search I finally found your thread. I got my php-imap working on centos 5.3 with directadmin custombuild. Thank you very much! :D
Thanks. I was looking at numerous pages that seemed very complicated, and after finding your post and the user who said his CentOS 5.3 went smoothly I gave it a try. Worked like a charm with my already-done custombuild on Centos.
