IT_Architect
- Feb 27, 2006
The IPs work. Please put me on your ignore list.
ICQed it to you.could you show this :
Code:ifconfig -a
The IPs work.
I will be shutting down this server shortly to take a snapshot, backup, and take a swing at getting it all to work with MySQL 5.1 before posting a How To. I don't expect to be successful as DA mentioned to me a couple months ago that they had not been successful due to a problem with the packages. The only way I've gotten 5.1 to work thus far is by using ports.could you show this :
They ping fine from here, and the pinging of those addresses has always worked. The vhosts were the only problem. Perhaps localhost can give them a ping and post whether he can ping them or not.No they don't. They do not respond to ping requests or http requests from remote testing facilities.
You've proven otherwise here.I can be trusted with confidential information when I am actually given confidential information.
The problem was solved before that. Read the thread. Localhost was the one on this thread who had an idea that surfaced exactly where the problem was. That occurred well before I realized I had type the wrong IP's in the PM.It revealed the mistake you made. So it was good that I did post it. Me posting it helped who? YOU.
You are tearing down your own image by making statements like that. This is not a student vs teacher venue. It's common knowledge that one person cannot compete with the knowledge and experience of a group. While not the case here, I and many others often leverage the synergy of a group even when they may have a solution in hand. The multiple viewpoints and experiences of other people most often produce a better solution than any individual idea.Look at the number of posts I have made throughout the years. Yet I have probably asked less than 10 questions here. There is a reason for that. You should learn to listen to ones who may know more than you. After all that IS why you asked your question here.
I don't understand why you would make such a statement. It's working fine, and I thanked everyone on this thread when it did.But I am guessing you still do not have it working and you are not willing to listening to ones who could help.
