i got a question about spamhaus.org
the exim.conf is setup to use this
#require verify = sender
# deny using spamhaus
deny message = Email blocked by SPAMHAUS - to unblock see http://www.example.com/
# only for domains that do want to be tested against RBLs
hosts = !+relay_hosts
domains = +use_rbl_domains
!authenticated = *
dnslists = zen.spamhaus.org
after a close look into the zen.spamhaus.org utility i found that this zone include 3 BL ... xbl.spamhaus.org sbl.spamhaus.org and pbl.spamhaus.org
but
like it is said in the spamhaus.org site ...
Should I use the PBL to block access to my webserver?
No! A listing in the PBL does not mean there is anything 'wrong' with the IP address or end user. A PBL listing does not mean an address is an open proxy or run by a spammer. All it means is that the IP address has been designated as 'not allowed to make direct-to-MX SMTP connections'. The majority of legitimate connections to webservers come from IPs listed in PBL. Please do not block innocent users.
http://www.spamhaus.org/faq/answers.lasso?section=Spamhaus PBL
so i wondered if it could be better to use the sbl-xbl.spamhaus.org insted of the zen.spamhaus.org to block incoming mail with exim
thanks
!authenticated = *
but
thanks
