error during installtion
seachen
hi ,
i have the following error during installation, may i know how to fixed it?
Your probably gonna want to install those things its complaining about with yum.
You can install custombuild by doing:
cd /usr/local/directadmin
wget "http://files.directadmin.com/services/custombuild/1.1/custombuild.tar.gz"
tar xvzf custombuild.tar.gz
cd custombuild
./build all d
cd custombuild
./build all d
Thanks for your reply;...
i have follow your cmd, but it still show out this error...
See posts #2 and #3.
gcc and g++ are required to compile apache and php
If you are not going to do what we tell you then we are all wasting our time.
I have done the installation.
But may i know what is my admin password?
What cmd to create my admin password?
At the end of the installation it tells you what the admin password is.
Ya, previously it have this , but dont know why i read few times, not found it.
anyway to reset the password?
check /var/log/directadmin/install.log
If not type:
passwd admin
and you can set a new one.
May i know how to check /var/log/directadmin/install.log?
It have the following error after i type the cmd
[root@server5 ~]# passwd admin
passwd: Unknown user name 'admin'.
[root@server5 ~]#
You should reinstall directadmin then I dont think it installed correctly.
hi try this:
yum install gcc cpp gcc-c++ flex make
and reinstall the panel.
good luck
yum install gcc gcc-c++ flex automake make ntp lynx nmap mc bison autoconf
WOW............... I suggest you just pay the little extra and have it installed by DA.
