grep: /usr/local/directadmin/conf/directadmin.conf: No such file or directory
Adding dovecot=1 to the /usr/local/directadmin/data/templates/directadmin.conf (template) file ...
Stopping DirectAdmin: cat: /var/run/directadmin.pid: No such file or directory
usage: kill [-s signal_name] pid ...
kill -l [exit_status]
kill -signal_name pid ...
kill -signal_number pid ...
[ FAILED ]
Starting DirectAdmin: [ OK ]
Shutting down exim: [ FAILED ]
Starting exim: /libexec/ld-elf.so.1: Shared object "libperl.so" not found, required by "exim"
[ OK ]
No matching processes were found
Stopping vm-pop3d: [ FAILED ]
./build: cannot create /usr/local/directadmin/data/admin/services.status.new: No such file or directory
cat: /usr/local/directadmin/data/admin/services.status: No such file or directory
mv: rename /usr/local/directadmin/data/admin/services.status to /usr/local/directadmin/data/admin/services.status.old: No such file or directory
mv: rename /usr/local/directadmin/data/admin/services.status.new to /usr/local/directadmin/data/admin/services.status: No such file or directory
chown: /usr/local/directadmin/data/admin/services.status: No such file or directory
chmod: /usr/local/directadmin/data/admin/services.status: No such file or directory
Adding conversion command to the task.queue ...
Executing the task.queue cotents now, please be patient ...
In debug mode
Debug set to level 10
root priv set: uid:0 gid:0 euid:0 egid:0
Unable to read config file. Check the file permissionsUnable to read config file. Check to make sure that /usr/local/directadmin/conf/directadmin.conf.lock doesn't exist
Restarting dovecot.
./build: /usr/local/etc/rc.d/dovecot: not found
Restarting exim.
[ OK ]
Done.
Installing dovecot 1.2.1 ...
id: dovecot: no such user
Found /usr/local/directadmin/custombuild/dovecot-1.2.1.tar.gz
Extracting ...
Done.
that's all i caught before it scrolled, i could probably figure it out but it's freebsd 7.2 32bit..
dovecot didn't start
is this thing even tested or what on freebsd
[ FAILED ]
[ OK ]
In debug mode
Restarting dovecot.
Restarting exim.
[ OK ]
Done.
Extracting ...
Done.
