What gets included in a reseller backup of admin?
IT_Architect
If you do a reseller backup, and it includes the admin user, does that backup include all of the domains under the reseller and/or all of the resellers under the admin?
A reseller backup of admin looks only at the admin reseller level. If you want to back up all the resellers you must select them separately.
A reseller backup of admin looks only at the admin reseller level. If you want to back up all the resellers you must select them separately.Jeff
Does it pickup the domains of the admin reseller with it or just the admin reseller?
My recollection is that it picks up the admin domains as well. You can always check :).
Never depend on a backup you haven't tested.
My recollection is that it picks up the admin domains as well. You can always check :). Never depend on a backup you haven't tested.Jeff
I will test. I was trying to save some steps. The only reason I was suspicious of that is it takes a longer than any of the users, yet it contains less information than any one of the users.
I've learned from sad experience over many years (I first started webhosting in 1995) that backing up a hosting server is never a place to save steps or time. Never.
