how reduce php load on my server ??
nimafire
hello.
i want reduce php load on my server.
so i have install eAccelerator .
now i have read some topics about xcache
some one do this method on their server:
MPM_Prefork+SuPHP+FastCGI+eAccelerator
mod_php+eaccelerator/xcache
how about you.?
what is your PROPOSAL about php cache system.
I use xcache and it seems to be working just fine... it shows a big difference when server loads are higher then normal.
Yes there is, I found it here on the site... you can try searching for it here... and I will look too
strange, after do step-2
Configuring for:
PHP Api Version:         20041225
Zend Module Api No:      20060613
Zend Extension Api No:   220060519
Cannot find autoconf. Please check your autoconf installation and the
$PHP_AUTOCONF environment variable. Then, rerun this script.
an step 3 won't work
[root@uk xcache-1.2.2]# ./configure --enable-xcache
-bash: ./configure: No such file or directory
ok. so am going to uninstall eAccelerator .
and how about installing this on 32bit ?
what about fastcgi ?
tnx
you just need to use the 32 bit version is all. you can browse the directory on the link and you will see the many versions.
Configuring for:
After you tar xcache-1.2.2.tar.gz go to that directory before then
Configuring for:
install autoconf
if you are on centos type yum install autoconf
