This makes site management easier, makes it easier to determine which user, if any, is sending spam through your server, and makes it much harder for attackers gain a foothold on your server, as the user running a script is limited to being able to only work as that user on files owned by that user, instead of all files managed by apache.
The main advantage of php_cgi is that it runs every php script as it's owner, and creates and modfies files as it's owner.
cli (using mod_php) is a lot lighter on system resources. On today's higher power systems it's not as important, and using mod_php (built into apache) apache doesn't need the time or memory overhead to start up another instance of php each time it comes across a php script.why do we have DA set cli as the default?
What about memory usage, is mod_php lighter or heavier (is there a diff between them in terms of memory)?
