directadmin for vps
seachen
may i know does DA offer directadmin license for vps?
Or the license for vps is same as normal dedicated server?
I have a directadmin license. can i install it into vps? the installation process is same as normal ?
If you offer VPS services you can get VPS licenses for $5.00 month. If you own your license you can use that on a VPS as well. Make sure the OS matches what's in the license file.
If o order internal license. can install into vps?
Internal licenses are for server providers. But yes internal licenses do work on VPSs.
