Installed SSL Cert Now Site is Down
brendanb
need some help
I purchased a cert for my domain www.getstuff.com.au
Followed the instructions per the site helper
http://www.site-helper.com/ssl.html
1. Got a Cert Request
2. Went and purchased the CA. Used a "QuickSSL Premium
3. Go the email with the cert
4. Pasted this "Underneath" the Cert Request
5. Then completed with "Install the CA Root Certificate"
Now my site does not work. I get "Redirection limit for this URL exceeded."
Im sure i followed the guide. Step by Step and im sure i didnt miss anything
Can anyone suggest what could be wrong?
brendan
ok here's an update
i can now get to the site, but when i checkout i get the following error.
HTML:
Not Found
The requested URL /checkout/onepage/ was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
what is going wrong here?
brendan
Must have something to do with the way your program is configured.
hi,
are there separate directories (public_html) for ssl and non ssl content?
hi,
YES you can select to make a link from SSL to standard in the CP though.
by default here is how it works
SSL > private_html
HTTP > Public_html
Just select the redirection option for ssl to public_html
hey scisi,
the reason i ask is, in my shopping cart if i disabled ssl on checout it works fine.
So im wondering is there a setting to tell the web server to use the same folders for the files than .. what i think its doing is looking for an ssl folder.
Apparently plesk had this, but im not sure about cpanel.
anyway,
cheers
right found the answer
In your domain setup you need to make sure you do the following
Use a symbolic link from private_html to public_html - allows for same data in http and https
see image
