So I moved a bunch of sites from a cpanel server to a DA server using the 'cpanel to directadmin' tool (great tool by the way!).
A couple of sites had Drupal installs working perfectly. After the move, the sites can no longer upload attachments either with Drupals upload module or fckeditors upload feature. Both show the file as uploading in the progress bar, but nothing is actually written to the server.
To try and figure out what might be going on, I install Drupal on a different domain on the same server using Softaculous. Same issue with the new install.
I have checked directory permissions, and they are all at 777.
Given that the new install of Drupal acted the same as the moved installs, I'm thinking it is something to do with the way DirectAdmin configures the server..
Any help would be appreciated.
