squirrelmail problem, mail stay in inbox
SajtXL
Hi all.
After upgrade to SM 1.4.19,
I can't move mail from my inbox to another folder.
When I marked a mail, and select "Move selected to..."
I received a copy in that folder,
but the original mail are still left in inbox ??
I have the same problem on two vps,
both running the latest version of custombuild.
It works with out any problem in Roundcube
Thank.
Is it a cache issue?
You can see if it's a local cache issue by logging out and then using a different browser to log back in and look at your inbox.
Even if that still results in you seeing the problem it could still be a cache issue; Squirrelmail could be caching it's html output. I don't have time to test this but perhaps if other users do, they'll look at it.
Hi Jeff, thanks for you answer.
Yes, I have try from both IE and Firexfox, ant still the same problem.
I have take copy from an old SM (1.4.17) and put all the data (except the data catalog) into my SM folder 1.4.19.
So the problem are solved, but I have to go back to 1.4.17.
