[tools] update.script
Do you like use update.script ?
  • yes, all time
    Votes: 221 69.1%
  • no, some time
    Votes: 44 13.8%
  • some time
    Votes: 55 17.2%
  • Total voters
    320
I am trying to install MailScanner, but I get an error:
Could not read directory /var/spool/mqueue at /opt/MailScanner/lib/MailScanner/Config.pm line 2784
Error in configuration file line 169, directory /var/spool/mqueue for outqueuedir does not exist (or is not readable) at /opt/MailScanner/lib/MailScanner/Config.pm line 3144
Done.
MailScanner install/update done
How can I fix this problem? /opt/mailscanner/etc/mailscanner.conf is empty.
CentOS 5+.
i have following error always. may i know what error ?
Done.
CentOS 5+.
did u try to install again ?
Wael
Hello, my /tmp folder has files of the type: dos-xxx.xxx.xxx.xxx, so I conclude that mod_evasive is working. But even if I wrote my email address in the configuration file, do not receive any warning about DoS attacks.
How do I check in CentOS if I'm running 32 or 64 bit? A little new to unix commands. ;)
Thanks. Do you know if there is any script out there (like this) that will secure the server (for x86)?
