email limit send mail
sander815
is it posible to set a maximum per user for sending email through smtp, f.i. 250 emails / day or so?
We'll be looking at something like that when we update exim and include the new exim.conf (jlaman's).. and integrated spamassasin controls. No eta though.
Hi im check the DirectAdmin Knowledgebase and works, but i want know if i can setup custom number of emails to some accounts, like:
admin - 2000 dayli mails
xxxx- 200 dayli mails
xxxx - 500 dayli mails
I don't think it can be done that way. Perhaps someone else will respond.
It is possible, but will require some adjustments. Please note that the following code is untested and usage is at your own risk
Create a copy of your exim.pl and open it:
cp /etc/exim.pl /etc/exim.pl.bak
nano /etc/exim.conf
Replace
sub check_limits
        my $count = 0;
        open (LIMIT, "/etc/virtual/limit");
        my $email_limit = int(<LIMIT>);
        close(LIMIT);
        #find the curent user
        $uid = find_uid();
        #log_str("Found uid: $uid\n");
        if (uid_exempt($uid)) { return "yes"; }
        my $name="";
        if ($email_limit > 0)
                #check this users limit
                if (($name = getpwuid($uid)))
                        $count = (stat("/etc/virtual/usage/$name"))[7];
                        if ($count > $email_limit)
                                die("You ($name) have reach your daily email limit of $email_limit emails\n");
                        open(USAGE, ">>/etc/virtual/usage/$name");
                        print USAGE "1";
                        close(USAGE);
                        chmod (0660, "/etc/virtual/usage/$name");
        my $sender_address = Exim::expand_string('$sender_address');
        my $mid = Exim::expand_string('$message_id');
        log_bandwidth($uid,"type=email&email=$sender_address&method=outgoing&id=$mid");
        return "yes"
With:
sub check_limits
        my $count = 0;
        $uid = find_uid();
        close(LIMIT);
        open (USERLIMIT, "/etc/virtual/$name.limit");
        my $user_limit = int(<USERLIMIT>);
        close(USERLIMIT);
        my $name="";
        if ($email_limit > 0 or $user_limit > 0)
               if ($count > $user_limit)
               print USAGE "1";
               close(USAGE);
        return "yes"
Create a limitation:
echo 300 > /etc/virtual/username.limit
And restart Exim:
/sbin/service exim restart
You can revert your changing as well:
rm -f /etc/exim.pl
mv /etc/exim.pl.bak /etc/exim.pl
Note that exim.pl is occasionally updated by DirectAdmin staff; when they do that you'll have to update your customized file yourself.
Good point.
I thought you could already set limits on a per user basis, but it seemed I was wrong. So perhaps there is someone else who can confirm this already is a feature.
Hello, i active the limit send per day, but the problem is in one user (mine) show me more than 111111 and im limit to 1000, and other thing, im just setup a new account im only sent 1 email but showme 11, so its working this system?
I do something like this in exim.conf:
warn ratelimit = 1000 / 12h / per_rcpt / strict
delay = 30s
log_message = Sender $sender_address rate $sender_rate / $sender_rate_period excedes limit delayed 30 seconds
This will throttle any IP that trys to send to over 1000 recipients in a 12 hour period. Not sure if that is something like you want or not. More info at exim.org on ratelimit. We also enforce another ratelimit is Squirrelmail.
Matthew
Just remember in the usage files 111111 is 6 emails. 11 is 2 emails.
        delay = 30s
I can see using this to avoid mail servers sending spam, but I'm not sure it will help you control your own users. Either they send email from your server (you can't block your own server from sending email) or they send it from their home or office connection on which the IP# will change.
Interesting point... should I perhaps consider adding this code to the SpamBlocker exim.conf file? Community input welcomed.
@hci:
Does your code also limit 127.0.0.1 (localhost)? If so, then won't it limit mailing lists run on the server?
I don't beleive so but it does limit squirrelmail. It can be setup to ignore 127.0.0.1 to avoid this. I have had spammers break into squirrelmail accounts though so I also added the limit senders plugin to squirrelmail and removed all other webmail clients.
Mattew
I'd like to see some additional input. Someone please update this thread by Monday morning if no-one else has, so I'll see it and act on it.
Thanks.
