Premature end of header scripts
carlo_gra
Hello, I've strange problem: recently I've upgraded my server and everything Is working fine except Roundcube and PhpMyAdmin.
I obtain "Premature end of header scripts" only for RC and PhpMyAdmin: SquirrelMail and UebiMiau are working fine. User's domains are working fine.
Permissions are ok.
Have you got ideas (I've recompiled all daemons)?
Thanks,
Carlo
Are you using php CLI (default) or php CGI (suPhp) ?
Try:
/usr/local/bin/php /var/www/html/roundcube/index.php
to see if you get any obvious errors.
Also try:
./build rewrite_confs
./build roundcube
Try:
Also try:
./build roundcube
I've solved by:
./build clean
./build php y
And without re-build RoundCube.
Thanks for your help. :)
