Mysterious php -v & phpinfo.php / Ioncube ...
pilatus
Hiya all !
I've followed the usual procedure to setup Zend Optimizer and Ioncube. So then i verify with php -v if they're active and behold, they are:
PHP 5.2.9 (cli) (built: May 15 2009 03:29:43)
Copyright (c) 1997-2009 The PHP Group
Zend Engine v2.2.0, Copyright (c) 1998-2009 Zend Technologies
with the ionCube PHP Loader v3.3.7, Copyright (c) 2002-2009, by ionCube Ltd., and
with Zend Extension Manager v1.2.2, Copyright (c) 2003-2007, by Zend Technologies
with Zend Optimizer v3.3.3, Copyright (c) 1998-2007, by Zend Technologies
BUT ... yes the big but here, when i load phpinfo.php it shows only this:
Zend logo This program makes use of the Zend Scripting Language Engine:
I'm trying to prevent pulling my last hair out, but could some one enlighten me ? :)
Thank you !
php on the shell is probably cli and the web one is cgi. Check the php.ini for cgi to ensure the zend lines are in it.
It's a no cgi setup, just cli and for the rest no custom work or so. Also there is only 1 php.ini file which is located here: /usr/local/Zend/etc/php.ini
(this is also shown in phpinfo.php)
