htaccess issue with denying ip range
LawsHosting
London UK
Offtopic regarding DA.....but......
I have a directory website, and 2 days ago I noticed 1,000's of submissions, which, to my knowledge is some sort of automatic submission software.
So I look at the logs to find that its from The Planet:
29.c6.7bae.static.theplanet.com - - [16/Feb/2010:21:48:20 +0000] "POST /blah HTTP/1.1" 302 396 "-" "-"
f4.c1.7bae.static.theplanet.com - - [16/Feb/2010:21:48:22 +0000] "POST /blah HTTP/1.1" 302 396 "-" "-"
ed.c3.7bae.static.theplanet.com - - [16/Feb/2010:21:48:23 +0000] "POST /blah HTTP/1.1" 302 396 "-" "-"
like 100's of random hostnames
....however, I blocked the IP range for them:
deny from 174.120.0.0 - 174.123.255.255
and
deny from *.theplanet.com
that didnt work (why?), so I did a whois for those hostnames, and found they have different ip's i.e 29.c6.7bae.static.theplanet.com = 208.187.80.135 ......
My question is this, why didn't blocking *.theplanet.com work?
As a temp measure, I had to use:
PHP:
   if ($_SERVER['HTTP_REFERER'] == "") {
      inl_header("http://www.spam.com");
      exit();
I know its a crude way......I'll add a captcha in due course.
Any insights?
Do deny lines require order ones as well? Or can you just use deny?
Example:
Order Deny, Allow
Deny from 174.120.0.0/14
Deny from .theplanet.com
Allow from all
I corrected the above code. Had a typo... This should work for you.
It worked. cheers. I can never understand the /16, /24, etc after the IP :confused: I always do 'deny from IP - IP', which normally works.
I also sent them an abuse report
Example:
Order Deny, Allow
Allow from all
Any examples I've seen of deny lines show them as you've written scsi. However I've noticed that it is not necessary when denying an I.P. or host name.
Ok I was just curious.
