CronJobs doesn't work
Scolpy
Hello!
over a month my CronJobs doesn't work.
I'm WHMCS and I uses the CronJobs to run the WHMCS cron file every midnight - and few months I'd no problems at all but some day the CronJobs stop to working, even I didn't made any changes in my server.
I spent the last few weeks trying to resolve this problem - but without any success.
This my CronJobs command:
php -q /home/*username*/domains/*domain*/private_html/cron.php
and this cron should run every minute, but it's doesn't work(it's work just if I navigate directly via browser to this file).
How Can I resolve this issue?
Yonatan :)
You probably need the full path to php on the line.
I also tried:
/usr/local/bin/php -q /home/*username*/domains/*domain*/private_html/cron.php
but it's doesn't work...
Try the same line from the command line (as the user whick should be running the cronjob), and watch for errors.
I resolved this problem.
probably, using the full path to php:
fixed the problem(just now I see that this cron-command actually works).
By the way,
there is any command to see all defined CronJobs in the server?
Yonatan
