How to overwrite default mysql-user 'Access Hosts'?
differentlocal
By defualt, users 'Access Hosts' contains only localhost.
But I need to add other IP to 'access hosts' of all users on the server for using remote phpMyAdmin (one for all servers). And create\modify template for new users.
How\where?
So you're posting again just to bring your post to the top of the list? After less than 24 hours? That seems a bit unfriendly to me. Give it a bit longer please. And only do it once or twice. If by then no one has answered it's probably because no one knows the answer.
Ok, sorry.
for give access to everyone into a specific database go into mysql setup into directadmin panel, go into the db you wanna edit and add % into access list
Thx, but I need to do that globally, for all users on server. Any way to do that?
maybe you need a post_create.sh script or a custom conf file that add automatically the % host for the created user (that wouldnt work for already existing) but for be more sure i suggest you to contact directadmin staff
