System Time and DirectAdmin Issues
cryptodan
What all do I need to do in order to repair the damage done by having the wrong system date?
I am unable to access directadmin via web gui, and other services are not working as well.
Any help will be greatly appreciated.
I hope I understand your problem. :)
You should use an SSH client (PuTTY). In the file
/etc/default/ntpdate
you will see, what kind of servers use the ntp. For example: 0.debian.pool.ntp.org
Than you give the command:
ntpdate 0.debian.pool.ntp.org
(Of course with your server.)
With this I could setup the server time.
Update: If necessary, restart the ntpdate. Command:
/etc/init.d/ntpdate restart
Well due to the CMOS battery running low the server was rebooted/moved to another area in the office, and well when it booted up it defaulted to August 15th 2005 so a lot of files and pid's are messed up. I got mail working, but the rest of DirectAdmin is dead. I cannot access it al via webgui.
I can use SSH just fine thats how I fixed the daemons and the pids to get mail working.
