adding users/domains in bulk
nobaloney
California
We've got a client who's just asked us to setup 136 users, each with one domain, on their owned server.
I believe there have been posts on how to automate this but even Googling, I couldn't find anything.
Has anyone done this? I don't want to reinvent the wheel if possible.
Thanks.
Hi Jeff,
You could do this as a CSV file import (with PHP):
<?php
include('httpsocket.php');
$server_ip="11.22.33.44";
$server_login="admin";
$server_pass="yourpass";
$server_ssl="N";
$sock = new HTTPSocket;
if ($server_ssl == "Y"){
	$sock->connect("ssl://".$server_ip, 2222);
}else{
	$sock->connect($server_ip, 2222);
$sock->set_login($server_login,$server_pass);
$arrtest = array();
if(($handle = fopen("import.csv", "r" )) !== FALSE){
	while (($data = fgetcsv($handle, 1000, ",")) !== FALSE) {
		$num = count($data);
		$arrtest = array(
		   'action' => 'create',
		   'username' => $data[0],
		   'email' => $data[1],
		   'passwd' => $data[2],
		   'passwd2' => $data[2],
		   'domain' => $data[3],
		   'package' => $data[4],
		   'ip' => $server_ip,
		   'notify' => 'no',
		   'add' => 'Submit'
		// print_r($arrtest);
		$sock->query('/CMD_API_ACCOUNT_USER', $arrtest );
		$result = $sock->fetch_parsed_body();
		if($result['error']!="0"){
			echo "<b>Error creating username ".$data[0]." on server $server_ip<br>\n";
			echo $result['text']."<br>\n";
			echo $result['details']."<br>\n";
		}else{
			echo "User ".$data[0]." created on server $server_ip<br>\n";
	fclose($handle);
	exit0;
set your CSV up like this:
username, email, passwd, domain, package
Note:
You should do more checking on this script - data input is "trusting" the CSV has correct data.
You get the httpsocket.php file from here:
http://files.directadmin.com/services/all/httpsocket/httpsocket.php
There's a stack of other options you can throw into the array:
http://www.directadmin.com/api.html#create
I've just tested this code and it works. Hope this helps you.
Jeff do you have the list of users and domains in a file? Or can your client do that for you?
I can make sure the CSV file has the correct data. I'm not a PHP kind of guy; care to contact me by email for further discussion?
I can create whatever I need. The client's list was horrible:
Domain names only, some in lowercase, some in uppercase, some in mixedcase, some singlespaced, some doublespaced, some even triplespaced, and with indents of various lengths :(.
But I've cleaned it up and now have a good list of domains, all lowercase.
I was hoping for a script which would take the first six characters of the domain name and then add a numeric series starting with 0001 and incrementing, to assure somewhat meaningful automated non-repeating usernames.
Do you have some ideas for me?
Hopefully this is readable. Perl code. Make sure LWP is installed. I will edit as necessary.
Put the domains in the domains.txt file.
The code will start with the number 001 and also use the first 5 digits of the domain plus the number for the username. Only the first 5 because DA by default only allows 8 character usernames.
Supply the variable information at the top.
$count = "001";
$dapackage = ""; #Package name. You have to create a package before adding users.
$daemail = ""; #Email for the new user. Don't forget to escape the @ sign like \@
$daip = ""; #Ip of the server
$daadminusername = ""; #The admin username
$daadminpassword = ""; #The admin password
open(FILE, ">passwordlist.txt");
use HTTP::Request::Common qw(GET);
use LWP::UserAgent;
use HTTP::Cookies; # Not sure if that is needed or not but doesn't hurt. I used to use it.
$ua = new LWP::UserAgent;
@domains = `cat domains.txt`;
chomp(@domains);
foreach $domains(@domains){
        $count = sprintf( "%03d", $count);
        $domain = substr($domains, 0, 5);
        $dausername = "$domain"."$count";
        &adduser;
        print FILE "$dausername\t$domains\t$dapassword\n";
        $count++;
sub adduser{
$dapassword=&generate_random_string(8);
$cmd = "CMD_API_ACCOUNT_USER?action=create\&package=$dapackage\&add=Submit\&notify=no\&username=$dausername\&email=$daemail\&passwd=$dapassword\&passwd2=$dapassword\&ip=$daip\   &domain=$domains";
$url = "http://$daadminusername\:$daadminpassword\@$daip\:2222/$cmd";
my $req = GET $url;
@results = $ua->request($req)->as_string;
print "@results\n";
sub generate_random_string
        $random_string = ""; #Clear out previous password
        $length_of_randomstring=shift;
        @chars=('a'..'z','A'..'Z','0'..'9'); # lowercase, capital, and numbers
        #$random_string;
        foreach (1..$length_of_randomstring)
                $random_string.=$chars[rand @chars];
        return $random_string;
Are you trying to spoil perl's reputation? It's supposed to be a write once, read never language, but your perl is actually readable :).
Your script is great! But it only uses only one password. What I need is for it to create random passwords (eight characters total, alpha/numeric, at least some of each, some caps, some lowercase) for each, and to save the list something like this:
username<tab>domain-name<tab>password
if possible.
Can do?
Thanks :D
Hi, could anyone rewrite @ranz code, but to only add multiple domains from domains.txt or csv file, to one user?
