What causes the Delete Bayes Data button to show?
IT_Architect
What causes the Delete Bayes Data button to show? I notice on one domain I have the option, and the others I don't.
Actually, this button has appeared on a new fresh server install of mine, maybe a new feature and update of skin? Doesnt appear on my other server.....
Would be interested to know too
Hey,
What skin are you using?
The coding in the enhanced skin does not appear to restrict when it shows up. It should always be there...
Thanks, David
Enhanced. It's kinda weird. I just logged back in to look at it again, hoping it would just go away. It's still the same. Most of the domains it doesn't display on, and some it does. I'm guessing it has to do when the domain was created, but it's only a guess. I tried disabling and enabling to see if it would make a difference, but it doesn't.
Edit: I fixed the problem by copying in a new enhanced skin. Instantly the button was available for all of the domains. I'm still mystified by both the problem and the cure.
