http://www.centos.org/
Anyone upgrade successfully? do it break DA or its component?
Thank you for your advice.
Regards
ccto.
Regards
ccto.
So far, it should work with DirectAdminRedHat Enterprise / CentOS 3.0, 3.1, 3.2, 3.3, 4.x, 5.0, 5.1, 5.2, 5.3, 5.4, 5.5 (64-bit: 4.1 - 4.5, 5.0, 5.1, 5.2, 5.3, 5.4, 5.5)
I dont have any problems, everything is still working for me.root:~# cat /etc/redhat-release
CentOS release 5.5 (Final)
gtk-update-icon-cache: symbol lookup error: /usr/local/lib/libpng12.so.0: undefined symbol: inflateInit_
error: %post(system-config-securitylevel-1.6.29.1-5.el5.x86_64) scriptlet failed, exit status 127
error: %post(system-config-services-0.9.4-5.el5.noarch) scriptlet failed, exit status 127
error: %postun(system-config-securitylevel-1.6.29.1-2.1.el5.x86_64) scriptlet failed, exit status 127
I got these errors during my update (64 bit CentOS)
[snipped]
Is this a serious problem?
Just updated my servers to 5.5, seemed to go smoothly without any hitches... everything seems to be behaving normally.
Firewall issue?
It could be, i will check again but everything else works and this issue wasnt there before the upgrade.
I hope its just a firewall issue![]()
Maybe you could check for CSF/LFD firewall (http://configservers.org/cp/csf.html) that should work easier also it has a webinterface into DA.UPDATE
it seems the update to 5.5 deleted apf (no idea) and this is the main problem, reinstalled apf but now having probs as apf isnt running on reboot, had to run apf -s and can now ssh in, getting there, but anyone else running apf?
