Cannot get pop3 to work with Outlook 2007.
vulcan762
Yep. Im new. Managing my own domains.
Trying to get my emails configured with Outlook 2007 pop3. No matter what, and yes...I searched first, I cannot get the email program to work correctly. My test msgs in Outlook fail but I "sometimes" receive a msg. My settings are exactly what the instructions said to be. Im lost.
Please provide us some error messages, because the information at the screenshot should be okay.
Do you have problems with receiving or sending?
If sending: Maybe your provider blocks port 25 to send mail with other mailservers. Then you need to use port 587 instead or use the mailserver from your provider.
daveyw, well that was the problem. I changed my port to 587 and all my test msgs work now. Thanks for taking the time to help. I really appreciate it. :-)
