Strange mysql.sock error during backup
SeLLeRoNe
Super Moderator
A Coruña, Spain
Hello everyone,
i never had this problem before and all DB are working fine (can see db from mysql db into directadmin and with phpmyadmin).
The problem is on administration backup, ive started a user backup from that section and message system after some minutes return this error:
Error while backing up database user1_db
mysqldump error output: mysqldump: Got error: 2002: Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2) when trying to connect
Ive checked /etc/my.cnf and /usr/local/directadmin/conf/mysql.conf and both got socket path line with correct path (/tmp/mysql.sock)
Anyone know if there is another part or file where i should set the socket path? Maybe in some admin backups conf?
Thanks everyone
i know i can do that way but that is just a workaround, i would like to know if there is a conf to change for the sock file on backups aswell
I don't have listed any socket thingy in /etc/my.cnf (so its using default)
Could you stop MySQL, remove the socket line, start MySQL again and try again to create backup.
Mine is '/var/lib/mysql/mysql.sock'
In the dir '/var/run/mysqld/' I have only the 'mysqld.pid'.
Ive found the problem.
There was another my.cnf in /etc/mysql/my.cnf with specific socket poiting to
Ive removed the directory /etc/mysql and restarted mysqld, now everything working good.
For who is interested this problem is related just on manual adinistrator backup, on administrator backup in crontab that error never appeared.
