Enabling AuthDigest on Apache 2.2.16
topdog
hi,
I'm running the latest DA version, CentOS 5.5 final 64 bit, and Apache 2.2.16.
I'm trying to enable the mod_auth_digest module, but can't seem to figure out how to.
Doing, as root: httpd -l
Doesn't show the digest module compiled in, although the htdigest program is present.
I tried putting in, as a test, in the /usr/local/directadmin/custombuild/custom/ap2/configure.apache file at the end
--enable-auth-digest \
It says that the command wasn't found during the configuration.
I'm attempting to enable this for WebDav, because in my domain's HTTPD log it says, as an error:
access to /webdisk failed, reason: verification of user id '<null>' not configured
I'd assume then that means I don't have the mod_auth_digest module loaded?
That's correct that you are getting the error.
It should look something like this
"--enable-proxy-http" \
"--enable-ldap" \
"--enable-authnz-ldap" \
"--enable-info" \
"--with-ldap" \
"--with-ssl=/usr" \
"--enable-headers" \
"--enable-cache" \
"--enable-mem-cache" \
"--enable-disk-cache" \
"--enable-file-cache" \
"--enable-auth-digest"
And not (what you did, as you are saying)
"--enable-ldap" \
"--enable-info" \
"--with-ldap" \
"--with-ssl=/usr" \
"--enable-cache" \
"--enable-auth-digest" \
It should look something like thisAnd not (what you did, as you are saying)
The error still persists.
/usr/local/directadmin/custombuild/custom/ap2/configure.apache: line 36: --enable-auth-digest: command not found
*** There was an error while trying to configure Apache 2. Check the custom/ap2/configure.apache file
Within that file is:
Again, this is for Apache 2.2.16, not Apache1.
This still doesn't want to compile.
Attached is my configure.apache file
I had to rename it to configure.apache.txt for upload, but hopefully I didn't put in the wrong syntax for mod_auth_digest
Ok finally got it to compile.
Your example had extra modules and I was confused.
As I don't have these extra mods I adapted the example.
After the enable headers statement I put a \
Then put
And it compiled.
The only problem now is when I try and upload any index.html or similar file, it gives in my error log an http error 405 error message.
Windows displays a warning that it cannot upload the file. yet any other file .txt .php uploads fine.
The only thing I can see in any log file, in particular my access log, is this:
[25/Aug/2010:20:35:37 -0400] "PROPFIND /disk/index.html HTTP/1.1" 405
Any other file uploads fine. Windows actually gives a retry and cancel button and just keeps looping back to the retry and cancel buttons.
