problem with mail
tza
i have a problem whit user not success to send mail from server or from site
This message was created automatically by mail delivery software.
A message that you sent could not be delivered to one or more of its recipients. This is a permanent error. The following address(es) failed:
[email protected]
Unrouteable address
[email protected]
Unrouteable address
------ This is a copy of the message, including all the headers. ------
Return-path: <[email protected]>
Received: from xxx-79-xx-xxx-xxx.red.xxxx.net ([xxxxxxxx] helo=ArthurPC)
by server1.yyyy.com with esmtpa (Exim 4.67)
(envelope-from <[email protected]>)
id 1OpF7S-0005bT-O9; Sat, 28 Aug 2010 09:42:26 +0300
From: =?windows-1255?B?5Oz08SAtIPru6evk?= <[email protected]>
To: <[email protected]>,
<[email protected]>
Subject: =?windows-1255?B?4ePp9+Q=?=
Date: Sat, 28 Aug 2010 09:42:22 +0300
Message-ID: <[email protected]>
MIME-Version: 1.0
Content-Type: multipart/alternative;
boundary="----=_NextPart_000_0001_01CB4695.50D0BE40"
X-Mailer: Microsoft Office Outlook 12.0
Thread-Index: ActGfCsnp3QK8L34SqOdpWpTf9YpFA==
Content-Language: he
MIME.
------=_NextPart_000_0001_01CB4695.50D0BE40
Content-Type: text/plain;
charset="windows-1255"
Content-Transfer-Encoding: base64
4ePp9/og+uXr7yDk6Pfx6A0KDQogDQoNCi0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0t
LS0tLS0tLS0tLS0tLQ0KDQogDQoNCuHr4eXjIPjhIC0g9uXl+iD67unr5A0KDQp3d3cuSEVM
LS0tLS0tLS0tLS0tLQ0KDQogDQoNCuHr4eXjIPjhIC0g9uXl+UFMu
Y28uaWwNCg0K5Oz08SAtIOD6+CDu4/jp6+ntIOXu4/jp6+kg5enj4OUg+ezqIQ0KDQogDQoN
Y28uaWwNCg0K5Oz08SAtIOD6+Cg==
Content-Type: text/html;
Content-Transfer-Encoding: quoted-printable
@tza:
Whomever set up your server should have properly configured your /etc/resolv.conf file to include two nameserver lines similar to the ones in my post linked to by Floyd (above).
You need two nameserver lines in that file, pointing to cacheing nameservers which should be supplied by your upstream service provider. If your upstream provider doesn't supply cacheing nameservers you can use Google's, as shown in my example in the post mentioned above.
You can use any command-line editor to edit the file on your server.
@floyd:
Thanks for the heads-up. Fixed.
It could also be possible the server admin used the /etc/virtual/limit file so he reached the limit of maximum mails.
True. The best thing to do is always check the logs first.
