Awstats and 2xDA Tally
inferencia
Spain
Hello guys,
I see directadmin tally happening at 23:30 and again at 00:10
[root@xxxx~]# cat /etc/cron.d/directadmin_cron
* * * * * root /usr/local/directadmin/dataskq
2 0-23/6 * * * root echo 'action=vacation&value=all' >> /usr/local/directadmin/data/task.queue;
#5 5 * * 0 root /sbin/quotaoff -a; /sbin/quotacheck -augm; /sbin/quotaon -a;
10 0 * * * root echo 'action=tally&value=all' >> /usr/local/directadmin/data/task.queue
20 4 1 * * root echo 'action=reset&value=all' >> /usr/local/directadmin/data/task.queue
0 4 * * * root echo 'action=check&value=license' >> /usr/local/directadmin/data/task.queue
0 23 * * * root /usr/local/directadmin/plugins/awstats/hooks/cgi-bin/awstats_updateall.pl now -awstatsprog=/usr/local/directadmin/plugins/awstats/hooks/cgi-bin/awstats.pl && echo 'action=tally&value=all' >> /usr/local/directadmin/data/task.queue
Is this correct :confused:
I think you've got the times wrong: 12:10 am and again at 4:20 am.
It should only happen once. On my machine that's at 12:10 am. My guess would be to set it at either midnight plus a few minutes or 4 am plus a few minutes, depending on whether your run your cron.daily at midnight or 4am.
Hi Jeff,
Thanks for your response. But I was making refference to these repeated tallies:
Why are there 2 tally all ? Is this correct? Should there only be one?
That one I don't know; I don't run AWStats. Hopefully someone else will respond.
Because one if for directadmin tally and the other is awstats only.
Just remove the && part if they run around the same time.
Excellent. We just weren't sure if there was a reason why both were running like 25 minutes apart. That's insane.
Thanks guys!
