Directadmin very slow
urgido
I have a problem.
My directadmin is very slow but all my websites are loading perfectly. Why?
Thanks.
Debian 5 x64
I can see all my sites online, but ssh connection is off and my directadmin is "out of sync" but I can see my login page.
Ok, let me see. This isn't a problem which we could fix by posting in forums.
If you're willing to pay someone to fix it for you, click here.
Otherwise you should contact your provider and see if they can help you.
this can be solved posting in this forum but with an answer of expert not newbie.
Try monitoring your server when browsing in DA. Use top or variants (htop) for example. Check if DA or an other process is asking much from your server.
You could also check for 'server-status' option and 'mod_security'
