how to change back all folder in 777 to 755 and file in 777 to 644
seachen
previous my server have no suphp.
i just install it into my server.
now i need to change my user website which have using folder permission 777 to 755.
if not the website cant run.
may i know any short cut which can make faster because i got few hundred website to do 1 by 1 . it taking long time.
cd /usr/local/directadmin/scripts && ./set_permissions.sh user_homes
find /home/*/domains/*/public_html -type d -print0 | xargs -0 chmod 711
find /home/*/domains/*/public_html -type f -print0 | xargs -0 chmod 644
cd /usr/local/directadmin/data/users && for i in `ls`; do { chown -R $i:$i /home/$i/domains/*/public_html;}; done;
(last line is all on one line)
Let said username is ckopi, domain name is ckopi.net
how to replace at the below code:
The code I, well, we, pasted will affect all users and their domains, which will ensure every domain will work.
You can however do, for ckopi:
find /home/ckopi/domains/ckopi.net/public_html -type d -print0 | xargs -0 chmod 711
find /home/ckopi/domains/ckopi.net/public_html -type f -print0 | xargs -0 chmod 644
chown -R ckopi:ckopi /home/ckopi/domains/ckopi.net/public_html
find /home/ckopi/domains/ckopi.net/public_html -type d -exec chmod 711 {} \;
find /home/ckopi/domains/ckopi.net/public_html -type f -exec chmod 644 {} \;
error 404 in mi page
i have that problem i dont know how to fix et can u help me
i oready have all the html file up i dont know what more to do
send me to mi hotmail a enser pliss
[email protected]
If you have access to root, just execute the shown steps (not the ones with ckopi), or contact your hosting provider for help.
hi.
thanks for your cmd that you provided.
i just migrate another server without suphp to a server with php.
now i need to follow the cmd that you provided 1 by 1.
any cmd that can 1 times fix all the permission and reset ownership?
do you mean just paste code below?
am i need to change any word? or just paste it? worry. haha.
@seachen,
What is your output for
# /usr/local/directadmin/directadmin c | grep secure_access_group
