How to reset / re-create user folders?
ozgurerdogan
USA
Sometimes some users deletes puplic_html folder or some other needed files. Is there a script which would allows to create default folders for a domain?
Thanks for the respond. Actually I need to re-create for one user only. But help show for all user. How can I modify those codes for my need?
You think this works:
#!/bin/sh
 i = "abc"
 for d in `cat /usr/local/directadmin/data/users/${i}/domains.list`; do
  mkdir -p /home/${i}/domains/${d}/public_html/cgi-bin
  mkdir -p /home/${i}/domains/${d}/private_html
  mkdir -p /home/${i}/domains/${d}/public_ftp
  mkdir -p /home/${i}/domains/${d}/stats
  mkdir -p /home/${i}/domains/${d}/logs
 done;
 mkdir -p /home/${i}/backups
 chown -R $i:$i /home/${i}
 chmod -R 755 /home/${i}
done;
exit 0;
Thanks in advance.
I don't know, what exact directories need to be recreated. Imap? SpamAssasin?
Change "abc" to your actual user name. And run the script
Perhaps, you'll need to fix rights on directories (ex. public_html). It depends on settings of your DA and related software.
I think this part of script:
sets the correct permission?
Compare with the other users's homes. In my case /home/username has 711 and is owned by username:username.
Do you have "apache_public_html=0" in your /usr/local/directadmin/conf/directadmin.conf or "apache_public_html=1"?
Is it set to 0
But I am not trying to create usernamed folder. Only I want to recreate folder in that user's domain.
That's ok, "0" is good. Just chown /home/username or /home/username/domains to username:username.
Skip the line "chmod -R 755 /home/${i}". It will set 755 on all files and directories within the location (insecure).
If you re-create domain directory, add "chmod 711 /home/${i}/domain/" somewhere before the loop or after.
Add "chmod 711 /home/${i}/domain/${d}" within the loop.
I think that's all.
Yes that was an other point. I am not totally re-create domain folder. Only folder that DA creates as default. So I could edit the script and make it work as follows:
#!/bin/sh
user=usernamehere
domain=domainnamehere.com
mkdir -p /home/$user/domains/$domain/public_html/cgi-bin
mkdir -p /home/$user/domains/$domain/private_html
mkdir -p /home/$user/domains/$domain/public_ftp
mkdir -p /home/$user/domains/$domain/stats
mkdir -p /home/$user/domains/$domain/logs
mkdir -p /home/$user/backups
chown -R $user:$user /home/$user
chmod -R 711 /home/$user
echo Done...
exit 0;
Can you please confirm that 711 is ok for /home/$user. Because when I look at other username I see 711. Also please note that I do not make any chmod for newly created folder.
711 for /home/$user is quite ok: apache, exim, dovecot need rights to access into user's home directory.
But if you want to be more secured (710 for /home/$user), you need to change much more, that is out of this topic.
You mean I should delete that line from script?
It's a bad idea to run it recursively. Plain text files (not executable scripts, like PERL) should have 644, not more.
If you want to do chmod recursively for directories only, run:
find /home/$user/*  -type d | xargs chmod 755
or
find /home/$user/*  -type d | xargs chmod 711
Be careful, with that command you can break user defined permissions on some directories.
Ok thank you. I think I do not need to set chmod for those default folder. So I deleted that line from script as I only need to re-create them.
