asishlla
- Jul 24, 2009
I installed security software called ConfigServer Security & Firewall - csf v5.15.
You can work with the software directly from the DA ,, and has option called Firewall Check.there is (ok status) and there is some WARNING need to fix like:
1) Check csf SAFECHAINUPDATE option (WARNING) This option closes a window of opportunity that opens when dynamic chain updates occur.
2) Check /tmp is mounted as a filesystem (WARNING) /tmp should be mounted as a separate filesystem with the noexec,nosuid options set.
3) Check /var/tmp is mounted as a filesystem (WARNING) /var/tmp should either be symlinked to /tmp or mounted as a filesystem.
4) Check SSH PasswordAuthentication (WARNING) For ultimate SSH security, you should consider disabling PasswordAuthentication and only allow access using PubkeyAuthentication
and athers WARNING
Can someone explain to me how it handles These warnings?
thanks.
and athers WARNING
thanks.
