Mysql 5.5
massive
I recently updated mysql to 5.5 and i am facing the following problem.
I am trying to install joomla and i am getting the following error :
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'TYPE=MyISAM CHARACTER SET `utf8`' at line 29 SQL=CREATE TABLE `jos_banner` ( `bid` int(11) NOT --------------------------------------------------------------------
Does anybody have experience with this?
Yap and here is the solution :
http://forum.joomla.org/viewtopic.php?p=2132134
I tested wordpress also and it works properly.
I have a customer running Joomla 1.5.22 on my server wich run MySQL 5.1.54. If I upgrade to MySQL 5.5x, I expect this site to stop working? If so, do you know how to fix a existing Joomla 1.5.22 site to work under MySQL 5.5x? To me, the link to Joomla forum seems to describe how to fix a new install, and not a existing one ...
5.5 is a development release and not suitable for production. Unless you have a specific reason to, you should not even consider running 5.5 for any production use.
I'm still running 5.1 on my server. No reason to upgrade :D
Nope it's production release :
http://dev.mysql.com/doc/refman/5.5/en/choosing-version.html
MySQL 5.5: Latest General Availability (Production) release
MySQL 5.1: Previous stable (production-quality) release
MySQL 5.0: Older stable release nearing the end of the product lifecycle
Reason for updating (Personal Opinion) :
Massive Increase in speed
You are wrong, ISOS6. 5.5.8x is a Generally Available (GA) Release, and it have been GA since version 5.5.8. Now we are at version 5.5.9, and I am considering a upgrade.
This have now been fixed in Joomla version 1.5.23 wich was released today: http://joomlacode.org/gf/project/joomla/tracker/?action=TrackerItemEdit&tracker_item_id=25162
However, I wonder how existing Joomla 1.5x installations will do after a upgrade to MySQL 5.5.x? Does we need to manually change something in their databases?
