Ability to Block domain name change to user
SeLLeRoNe
Super Moderator
A Coruña, Spain
i would like to see an option on user/package creation to enable/disable the option to add/rename/remove a domain at user level.
Example:
User1 buy aaaaa.com and i add the package and domain for the User1
User1 once logged can go to domain administrator and rename/delete/add new ip (once deleted old one) without admin control or notify.
I would prefer that if i add a domain the user cannot for any reason delete/rename that.
So, ofc is not a good idea block this function, but, have the ability to limit this "power" should be a nice feature i think.
Thanks, regards
that would be nice, but, will remain the domain setup in user level skin...
maybe the way i proposed should be better cause with an "if" on skin user leve would disappear the option too
Lets see other users and da staff what think about this :)
how can i be able to creat phpmailer from my webhost
thank you but how can i be able to creat phpmailer from my webhost
I also would like to see this feature. As we do not use DNS on our boxes, if they change the domain name, they need to also change the DNS elsewhere - they can forget to do this.
Maybe it could be an User Package feature.
