Cant connect to local MySQL server through socket?
beansbaxter
WA
Within DA, I chose a Restore Backup file and during the restore, I get the following error:
Unable to restore database filename.sql to database : ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/home/mysql/mysql.sock' (13)
MySQL is obviously running because the other websites on the server are loading up fine.
How can I troubleshoot and get this resolved?
Thanks in advance.
Better make sure you put it in the right section in my.cnf or you will have issues.
Could you please tell me where is the correct place so I can check to make sure I put it in the correct place.
What kind of issues are known to happen otherwise?
