name servers
igorif
Hello, please help me.
1. How do I know which IP to ns1.mydomain.com, ns2.mydomain.com put me in my setup?
2. How do I change them? Where?
Advice please.
Thanks, but that's not what I asked.
Look at you there is http://www.directadmin.com/forum/showpost.php?p=70770&postcount=14
ns1.findlocal.org. A 72.36.205.154
ns2.findlocal.org. A 72.36.205.155
how do I do that I had also had a different ip?
I now have this:
ftp A 46.4.88.61
localhost A 127.0.0.1
mail A 46.4.88.61
pop A 46.4.88.61
server.franuk.com. A 46.4.88.61
smtp A 46.4.88.61
www A 46.4.88.61
server.franuk.com. NS ns1.franuk.com.
server.franuk.com. NS ns2.franuk.com.
mail MX 10
I understand I have now so worth it:
ns1.franuk.com. - 46.4.88.61
ns2.franuk.com. - 46.4.88.61
and I need that would be
ns2.franuk.com. - 46.4.88.78
IP 46.4.88.78 bought in Data center. As it is now put on ns2.franuk.com. ?
on the registrar-site you must (or should) register this IPs with ns1/ns2
on DA-side you add IPs in the IP-management, after goes in the reseller-level under extra-features you find Nameservers, there add IPs to your ns*.domain.xy and then back in admin-level you set this 2 new ns-names in the administrator-settings (extra-features) to be default for new domains.
was this the question?
ps: for existing domains in the admin - dns administration
with the same IP - i dont know
check your settings here http://www.intodns.com/
Thank you, but do not quite understand what to do next? How do I attach to ns1.franuk.com - IP 46.4.88.58?
Please show in the photo, it would be very good.
I would be very grateful.
looks like you have no domain added to your controlpanel (ie you as admin, in the userlevel)
normally, you should check the both IPs, choose a domainname in the dropdownlist (which here seems to be empty, you need domainname first) where you wants your NS to belong to, and click create-button, then you should see it in the tab nameserver and finally also in the admin-level in the ip-manager.
go add an domainname.
you need "franuk.com" added in your DA, after that you can set ns*.franuk.com
http://www.intodns.com/franuk.com
WWW A Record ERROR: I could not get any A records for www.franuk.com!
SOA record No valid SOA record came back!
Nameservers A records ERROR: Some of your DNS servers do not have A records at all. I could not find any A records for the following DNS servers:
ns1.hc.ru
ns2.hc.ru
You must have A records for all of your nameservers.
DNS servers responded ERROR: One or more of your nameservers did not respond:
The ones that did not responded are:
ns1.hc.ru ns2.hc.ru
ns1.hc.ru
ns2.hc.ru
ns1.hc.ru ns2.hc.ru
Yes, thanks, yet didn't change in the domain name servers. A problem in that what correctly to make options in directadmin what trouble-free to pass to the new server.
Many thanks for the help, whether I know correctly all has made. Time will tell. I hope that all has correctly made.
if you add new IPs to nameservers you should wait really 2 days - it took much more longer time to propagate the IPs, as simple domain-changes in nameservers only in few hours..
good luck!
good luck!
Like added, such as working ..
But ns2 - does not work (IP added to the DA today. And he bought today IP 46.4.88.58). May need to wait?
Please look again, what can I do something wrong?
Contact your hosting provider:
ping 46.4.88.58
PING 46.4.88.58 (46.4.88.58) 56(84) bytes of data.
From 46.4.88.33 icmp_seq=1 Time to live exceeded
From 46.4.88.33 icmp_seq=2 Time to live exceeded
From 46.4.88.33 icmp_seq=3 Time to live exceeded
From 46.4.88.33 icmp_seq=4 Time to live exceeded
--- 46.4.88.58 ping statistics ---
4 packets transmitted, 0 received, +4 errors, 100% packet loss, time 2999ms
IP is not reachable.
A record looks fine now, main IP is ok.
Go and search the Email from Hetzner, where they send you the IP-Range. Check the NETMASK ! Correct it. Try again.
And - by the way - dont take the first and the last IP from your new Ip-range !
