Installed DirectAdmin - No Connection
AdWarm
Hi Guys,
I have just installed DA on my new VPS and everything was installed fine and i have the admin login details. How ever i am not able to connect to port 2222. I have tried restarting the VPS but still have the same problem. The VPS was new and fresh with nothing on it.
Any help would be great.
Also if i just enter the IP without the port i get the message "Apache is functioning normally" so i know everything was installed fine.
Check the value of your ethernet_dev=vnet0:0 setting in your /usr/local/directadmin/conf/
directadmin.conf file and the output of /sbin/ifconfig<br>
2011:04:09-21:47:02: ioctl can't find the server's ip address for vnet0:0 : No such devic
e
2011:04:09-21:47:02: The ip of this machine () does not match the ip in the license file.
<br>
2011:04:09-21:47:12: ioctl can't find the server's ip address for vnet0:0 : No such devic
e
2011:04:09-21:47:12: The ip of this machine () does not match the ip in the license file.
<br>
But vnet0:0 does exisit
venet0:0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:69.160.241.204 P-t-P:69.160.XXX.XXX Bcast:69.160.XXX.XXX Mask:255.
255.255.255
UP BROADCAST POINTOPOINT RUNNING NOARP MTU:1500 Metric:1
I removed bits of the IP and replaced it with XXX for my security. As for the License not being registered to the IP it should e as its the main VPS's IP. Iv now contacted my provider and asked them which IP the license was registered too.
If it's important for you, ask an admin or a moderator to update your post.
So it's solved, wrong interface name was the reason, isn't it?
Crap, i cant even edit the post :(
There's really no reason to; it's not a security issue to let the world know you have an IP#. It's always going to be given out by your namesever anyway.
For more information see this page.
The reason you can't edit your post is probably because you're not yet a verified user.
