(98)Address already in use: make_sock: could not bind to address 0.0.0.0:80
Status
Not open for further replies.
Highway
Since 2 days have I an big problem.
Every 2 - 4 hours, apache will stop working.
When i type: /etc/init.d/httpd restart it says:
(98)Address already in use: make_sock: could not bind to address [::]:80
no listening sockets available, shutting down
I have the same problem on another DirectAdmin server, but on that server stops apache in one time in the 2 weeks.
Have anyone had the same problems? And how to solve it? I've googled, but found not much.
OS CentOS 5, apache 2.2.
Thanks in advantage!
Regards,
Highway.
Please post the output of:
netstat -lnp | grep :80
Hi Smtalk,
Thanks for your answer. When apache is stoped again, I post here the output.
I've done this previously, but I can't remember me any special on port 80.
Kind Regards,
Highway
I have the same problem and i get this output
[root@server b]# netstat -lnp | grep :80
tcp 0 0 :::80 :::* LISTEN 15576/ns.pl
Thanks for all help
Best regards from Morten Buljo
Thanks for all help
Try killall -9 ns.pl
Does'nt work that, please run: updatedb and then give the output from:
locate ns.pl
ns.pl is'nt present on my server, with locate the server tell's you what ns.pl's path is.
I kill all and restart httpd and it working now, but what cause the problem ? so we can fix the problem :)
I don't know at this time.
Apache is on my server stoped now.
[root ~]# netstat -lnp | grep :80
tcp 0 0 :::80 :::* LISTEN 13481/hugobloc.pl
So on your and my server both an pl script.
Edit: I do now an updatedb, so I can check where it come from. This take a while, time for coffee.
Edit 2: It founds nothing!? :s
I try to restart my httpd and get this message
[root@server p247com]# /sbin/service httpd restart
Stopping httpd: [ OK ]
Starting httpd: [Sun Nov 01 19:43:28 2009] [warn] module php5_module is already loaded, skipping
Unable to open logs
Stopping httpd: [FAILED]
Starting httpd: [Sun Nov 01 19:43:43 2009] [warn] module php5_module is already loaded, skipping
Unable to open logs
[root@server p247com]# netstat -lnp | grep :80
tcp 0 0 :::80 :::* LISTEN 12839/ixko.pl
EDIT
[root@server /]# netstat -lnp | grep :80
tcp 0 0 :::80 :::* LISTEN 12840/ixko.pl
[root@server /]# kill -9 12840
tcp 0 0 :::80 :::* LISTEN 12841/ixko.pl
[root@server /]# kill -9 12841
tcp 0 0 :::80 :::* LISTEN 12842/ixko.pl
[root@server /]# kill -9 12842
[root@server /]# netstat -lnp | grep :80 <-- and then httpd start automatic
tcp 0 0 :::80 :::* LISTEN 5861/httpd
[root@server /]#
Looks like some exploits on DA servers. I had this one lately on a server that we were going to migrate from. Since we had to cancel that server I did not have enough time to inspect.
When I say exploits on DA servers, I really don't mean DA has some vulnerability :)
Check your FTP log.. i guess the perl scripts were uploaded and deleted in 1 second (= uploaded, started and removed by bots :))
Yes, that is true. On one strange reason dit some users had CGI access.
Today was apache down again.
netstat -na | grep -i list | grep 80
unix 2 [ ACC ] STREAM LISTENING 5180 /var/run/dovecot/dict-server
Nothing to see :S
Seeing the same
I am seeing the same issue:
[root@srv01 run]# service httpd restart
Starting httpd: [Fri Apr 15 15:54:27 2011] [warn] module jk_module is already loaded, skipping
[Fri Apr 15 15:54:27 2011] [warn] module ssl_module is already loaded, skipping
Unable to open logs
[FAILED]
[root@srv01 run]#
[root@srv01 run]# netstat -lnp | grep :80
tcp 0 0 :::80 :::* LISTEN 4658/httpd
[root@srv01 run]#
Any ideas!?
you have to find those file .pl and stop cgi on that domain, one of your user has been hacked.. prolly some permission wrong.
Regards
sadly .. i do not have control over the box, helping a friend with their server and this is after a plesk upgrade to 10.2 .. so that might be part of the issue
You're on a DirectAdmin forum. Questions for Plesk should be addressed to a Plesk forum. the two control panels are quite different from each other and may need totally different solutions.
same error
I am trying to install memcached now at the part where i need restart apache2 and get this
server:/# /etc/init.d/apache2 restart
Restarting web server: apache2(98)Address already in use: make_sock: could not bind to address 0.0.0.0:80
Unable to open logs
failed!
server:/# netstat -lnp | grep :80
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 1336/httpd
server:/#
Unable to open logs
failed!
server:/#
sorry for the double post....I killed the httpd processes and apache2 started fine but then httpd got the same error when i tried to start it, seems i can have one or the other not both running at one time
Of course you can't; httpd and apache2 are both names for the apache webserver.
You've probably got multiple apache servers on your system, both set to start up automatically.
Status
