Panel not working after installing configserver firewall
hostingsolution
Dear team
i install the configserver firewall on my vps and after this i m unable to load the panel so do the needfull
of course doesnt work, i need the result of that command for see if directadmin is listening on right port and for understand if is fw related or not...
mmh seems that directadmin is set for using a ethernet card that is not present on system...
paste the result of:
ifconfig
well, you need to find the main ip of the server in that list and identify the associated eth card, and change it in /usr/local/directadmin/conf/directadmin.conf
Regards
