SeLLeRoNe
Super Moderator
Well have clamav in custombuild is just nice for automatization, ofc you wrote a guide and your script does alraedy that.. but... for who didnt use just a one-command line would be very helpful i suppose.
I used to install via update.script that is the same as custombuild.. just for dont have to write in the script all the steps for get it installed.
I dont get this, you mean new versions of your script or custombuild?
Ofc if is your script is up to you choose how make it work i was just giving my 2 cents
On my side i dont see for now a valid reason for dont install clamav and/or spamassassin so i dont need that kind of choise. Ofc, in your case, the perl part is the best way for doing it
But ive my customized exim file that would work for any default installtion (or my own custom if is better to say) that i do.
Best regards
From my understanding, in future versions it will just be a matter of uncommenting one line for SA and ClamAV if you choose to use it. In my opinion, that is the way it should work.
Best regards
