How to uninstall ClamAV on centos?
Dauser2007
hi,
How to uninstall ClamAV on centos? after i CustomBuild ClamAV i got mysql automatic stop, and apache looks like hung too. i have to restart apache then everything back normal. i think which is ClamAV problem ! so i wanna remove that from box. hope someone can help around !
thanks!
Dauser
There is no way to remove things installed from source unless you know where it put all the files and then you just delete them.
There may be a make target in the source code tree for uninstall; if there is you can cd to the source code tree and run:
# make uninstall
If the target doens't exist, then you need to find the executable file and uninstall it manually, and then remove the source directory and it's contents.
i have Question here i have whm Access with Root But cpanel not Allow to me upload any simple File like php
i have root access Can any body knonw how to bypass this
Please. Check file dates and don't necropost with some totally different issue in a 11 years old post.
Create a new post for your issue.
Also if you run cPanel, you're on the wrong support forum.
