Quota correct but DA not showing accurate total disk usage
keefe007
For some reason DA is not showing correct disk usage on my server, which is causing problems for users. Users are using up their disk quota but DA is not sending them a warning or showing their actual disk usage.
Here's an example:
astra:/etc/init.d# quota -vs wired
Disk quotas for user wired (uid 1083):
Filesystem blocks quota limit grace files quota limit grace
/dev/sda1 0 0 0 0 0 0
/dev/sda5 6288M 10000M 11000M 33812 0 0
The quota command is showing the correct disk usage, however, DA shows the following:
Total Disk Usage (MB) 2394.4 10000
Email Disk Usage 2.34 GB
Database Disk Usage 0.00 KB
The interesting thing is that when I login as the user and go into "email accounts" the correct email usage is showed. Here's what i see:
Total Usage: 6283.8 Meg
How can i fix this?
Thanks,
Keefe
make sure your cronjob runs which updates the values
Would you please let me know what crons?
Also the DA API is showing strange numbers witch is pretty much different that what is in real,
I have exactly the same problem like Keefe007, any one have any idea to help me fix i?
here have captured screens.
