External Wildcard DNS records
LawsHosting
London UK
Quick question.
If a domain has a wildcard (*) A record (not on the box), and the sub-domain (eg. test.) doesn't exist, is it normal for Apache to return the main vhost (domain.tld) for that sub-domain even if the ServerAlias hasn't a *.domain in it? :confused:
As we do not use nameservers on our boxes, I tell clients to add a wildcard A record so when they add sub-domains, they do not need to add an A record everytime.
If a wildcard (*) A record is set up, and a correct IP is assigned, it's up to you to configure Apache (add necessary domains, sub-domains) in order to get what you want.
If a requested domain or sub-domain does not exist, a user will see (with default apache and directadmin setting) either a stub with "Apache is functioning normally" or "This IP is being shared among many domains".
Of course if it is a dedicated IP (assigned to a user IP), then you'll see an index page of a default domain of the account.
Ok, so if a domain is on a shared IP, then it'll look at the sharedip index.html.
I'm asking for SEO reasons, like if a domain has a dedicated IP (my example), then search engines could index non-existent sub-domains, thus come under duplicate content - or even someone could submit wesuck.domain to search engines.
At the moment I added this to the htaccess:
RewriteCond %{HTTP_HOST} ^test.domain.tld$
RewriteRule ^(.*)$ - [R=410]
I was going to do this, but I realised it'll catch real sub-domains too:
RewriteCond %{HTTP_HOST} ^(www.)?([a-z0-9-]+).domain.com$
