Install Zend on CentOS
RAGOpoR
is this solution incorrect ?
is it possible to install Zend Server CE or Zend Server license with directadmin ?
after i run this command my php on server are not work, any idea ?
./build clean
./build zend
File already exists: ZendGuardLoader-php-5.3-linux-glibc23-x86_64.tar.gz
Zend Guard Loader has been installed.
[root@xs1 custombuild]# php -v
PHP 5.3.6 (cli) (built: Aug 13 2011 20:56:01)
Copyright (c) 1997-2011 The PHP Group
Zend Engine v2.3.0, Copyright (c) 1998-2011 Zend Technologies
with Zend Guard Loader v3.3, Copyright (c) 1998-2010, by Zend Technologies
Zend Server is not ZendGuard...
You didnt gave any error, log or any usefull information for help you with your issue.
Regarding Zend Server on DA Server, MAYBE, with a lot of customization, should be done on a separate port (different from apache that use 80) and with virtual redirects using apache as proxy.
Regards
Regards
Thank you for your information.
according to This server running as production, i have to restore it.
could you please show me the solution to enable zend , e.g. zend optimizer
or solution for Zend Server ?
thank you
You still didnt gave enough information.
Check /var/log/httpd/error_log
Try rebuild php using
/usr/local/directadmin/custombuild/build php d
For recompile php (maybe apache lost the mod for some reason).
Regards
Regards
the issues happen between 13.25 - 13.45
i think it no log about php error ?
anyway according to your advise i will try to enable zend and rebuild php again
[Fri Sep 02 00:10:02 2011] [notice] SIGHUP received.  Attempting to restart
[Fri Sep 02 00:10:03 2011] [warn] RSA server certificate CommonName (CN) `localhost' does NOT match server name!?
[Fri Sep 02 00:10:03 2011] [notice] Apache/2.2.19 (Unix) mod_ssl/2.2.19 OpenSSL/0.9.8e-fips-rhel5 DAV/2 SVN/1.6.5 PHP/5.3.6 configured -- resuming normal operations
[Fri Sep 02 00:11:01 2011] [notice] caught SIGTERM, shutting down
[Fri Sep 02 00:11:02 2011] [warn] RSA server certificate CommonName (CN) `localhost' does NOT match server name!?
[Fri Sep 02 00:11:02 2011] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Fri Sep 02 00:11:03 2011] [warn] RSA server certificate CommonName (CN) `localhost' does NOT match server name!?
[Fri Sep 02 00:11:03 2011] [notice] Apache/2.2.19 (Unix) mod_ssl/2.2.19 OpenSSL/0.9.8e-fips-rhel5 DAV/2 SVN/1.6.5 PHP/5.3.6 configured -- resuming normal operations
[Fri Sep 02 02:37:49 2011] [error] [client 203.172.175.251] File does not exist: /var/www/html/w00tw00t.at.blackhats.romanian.anti-sec:)
[Fri Sep 02 02:37:49 2011] [error] [client 203.172.175.251] File does not exist: /var/www/html/404.shtml
[Fri Sep 02 02:37:49 2011] [crit] [client 203.172.175.251] (13)Permission denied: /var/www/html/phpMyAdmin/scripts/.htaccess pcfg_openfile: unable to check htaccess file, ensure it$
[Fri Sep 02 02:37:49 2011] [error] [client 203.172.175.251] File does not exist: /var/www/html/403.shtml
[Fri Sep 02 02:37:49 2011] [error] [client 203.172.175.251] File does not exist: /var/www/html/pma
[Fri Sep 02 02:37:49 2011] [error] [client 203.172.175.251] File does not exist: /var/www/html/myadmin
[Fri Sep 02 02:37:49 2011] [error] [client 203.172.175.251] File does not exist: /var/www/html/MyAdmin
I dont see any relevant error here.
What problem you got exactly?
From your php -v seems that zend is installed.
i do following your advise
after enable zend then build zend
then recompile php, it seem php work well but what about zend optimizer ?
i don't know why it install only Zend Guard, any idea ?
PHP 5.3.6 (cli) (built: Sep 2 2011 12:37:24)
Zend Optimizer doenst exist on php 5.3
Thats why it install Zend Guard.
Regards
Thank you for your help SeLLeRoNe
Can i ask more question?
is custombuild support Zend Server CE?
if i download and manual install Zend Server CE
it will be conflict with Directadmin ?
That probably not, but im not sure... Is possible that will no conflict but for sure you need to use zend server not on default 80 port.
Never tested, so i cant be sure, you need to try it on your own im sorry.
Regards
Regards
Thank you SeLLeRoNe.
