Error with system Quotas
kevinwalter
I've got an OpenVZ vps here with CentOS 5.5 64bit.
If I create an account I'm getting this error:
Unix User created successfully
setquota: Mountpoint (or device) / not found. setquota: Not all specified mountpoints are using quota.
Debug Guide
User's data directory created successfully
Domains directory created successfully
Domains directory created successfully in user's home
Domain Created Successfully
User added to ssh config file.
How can I fix this?
Already tryed this one: http://help.directadmin.com/item.php?id=42
Greetz,
Kevin
Oh right, i had read but i had forget about it..
Actually ive no idea at the moment...
You need to add usrquota and grpquota to your / partition (is required also in da installation)...
Hope someone else with experience with OpenVZ box will reply...
Sorry
Note, in OpenVZ VE you won't see much with
# cat /etc/fstab
You should run instead:
# mount
and if you see anything like this:
# mount
/dev/simfs on / type reiserfs (rw,usrquota,grpquota)
proc on /proc type proc (rw)
sysfs on /sys type sysfs (rw)
none on /dev type tmpfs (rw)
devpts on /dev/pts type devpts (rw)
tmpfs on /tmp type tmpfs (rw,nosuid,noexec)
none on /proc/sys/fs/binfmt_misc type binfmt_misc (rw)
That's OK, if not.... Ask your VPS provider to enable second level quotas for your VE on HN.
One more, you won't see much with
# quota
you'd better use something like:
# repquota -a
as I've got
# quota
Disk quotas for user root (uid 0): none
and
# repquota -a
*** Report for user quotas on device /dev/simfs
Block grace time: 00:00; Inode grace time: 00:00
                        Block limits                File limits
User            used    soft    hard  grace    used  soft  hard  grace
root      -- 33825572       0       0         148220     0     0
daemon    --       8       0       0              3     0     0
mail      --   42640       0       0           1429     0     0
games     --      16       0       0              2     0     0
ftp       --    6428       0       0            117     0     0
vcsa      --       8       0       0              1     0     0
rpm       --   33612       0       0             16     0     0
named     --    2732       0       0             41     0     0
smmsp     --      92       0       0             23     0     0
apache    --   79152       0       0            817     0     0
diradmin  --  269848       0       0          15551     0     0
mysql     -- 1449676       0       0          30594     0     0
webapps   --  698952       0       0          20847     0     0
majordomo --     940       0       0            172     0     0
dovecot   --       0       0       0              3     0     0
admin     -- 9859920       0       0           2751     0     0
Thanks for that reply.
I'm getting this:
[root@host ~]# mount
/dev/simfs on / type simfs (rw)
none on /dev/pts type devpts (rw)
[root@host ~]# repquota -a
[root@host ~]#
