Backups - 500 Internal server error
kan3
What's the best way to backup mysql + all the directories? Currently DA backups everything (mysql + directories). But when it does, my site starts giving 500 Internal server error. When the backup finishes the site goes back to normal.
Please see the attached image, mysql is using 100% CPU.
Thank you.
Actually you would need more performant server.
You should use script but the result would be the same...
Regards
Intel Quad + 6 GB RAM, I think it's performant server.
Any script you recommend?
Well, yes is a nice box but should depend on how many websites and visit there are...
Try as zeiter sayd the mysql tuner cause the mysql load was at 99+%
Regards
Well there was a problem with sphinx, had nothing to do with webserver.
Thank you.
