You have /var partition. MAKE SURE* its adequately large (6 gig or larger)
Anton
Iceland
Filesystem            Size  Used Avail Use% Mounted on
/dev/sda5             9.9G  384M  9.0G   5% /
tmpfs                1004M     0 1004M   0% /dev/shm
/dev/sda1             485M   45M  415M  10% /boot
/dev/sda8             249G  188M  236G   1% /home
/dev/sda7            1008M   34M  924M   4% /tmp
/dev/sda3              12G  557M   11G   5% /usr
/dev/sda2              20G  274M   19G   2% /var
but i get this ?
*** You have /var partition.  The databases, emails and logs will use this partition. *MAKE SURE* its adequately large (6 gig or larger)
Press ctrl-c in the next 3 seconds if you need to stop
Installation didn't pass, halting install.
when i try installing directadmin ? on 64 -bit centos 6
[root@server1 ~]# ll /var
total 80
drwxr-xr-x.  4 root root   4096 Sep 22 16:48 cache
drwxr-xr-x.  2 root root   4096 Nov 11  2010 db
drwxr-xr-x.  3 root root   4096 Sep 22 16:49 empty
drwxr-xr-x.  2 root root   4096 Nov 11  2010 games
drwxr-xr-x. 13 root root   4096 Sep 22 19:20 lib
drwxr-xr-x.  2 root root   4096 Nov 11  2010 local
drwxrwxr-x.  3 root lock   4096 Sep 22 16:48 lock
drwxr-xr-x.  3 root root   4096 Sep 22 19:36 log
drwx------.  2 root root  16384 Sep 22 16:44 lost+found
lrwxrwxrwx.  1 root root     10 Sep 22 16:48 mail -> spool/mail
drwxr-x---.  5 root named  4096 Sep 22 19:41 named
drwxr-xr-x.  2 root root   4096 Nov 11  2010 nis
drwxr-xr-x.  2 root root   4096 Nov 11  2010 opt
drwxr-xr-x.  2 root root   4096 Nov 11  2010 preserve
drwxr-xr-x. 10 root root   4096 Sep 22 19:40 run
drwxr-xr-x.  8 root root   4096 Sep 22 16:49 spool
drwxrwxrwt.  2 root root   4096 Sep 22 19:56 tmp
drwxr-xr-x.  2 root root   4096 Nov 11  2010 yp
[root@server1 ~]# cat /etc/fstab | grep /var
UUID=c42d3acc-1e7e-4c84-819e-5c8d071f6a89 /var                    ext4    defaults        1 2
Ok, i totally missread the output.
Is just a notice
He say, ok you got /var mounted.. be sure is 6+GB space.. your is 20GB so no worries, also, if you use dovecot the mail will be stored in user's own home directory (/home) so.. seems to be ok...
Regards
Is just a notice
Regards
:) yes but the worst thing is that i can't continue with the install because it says that i do not have 6 gig or larger ? what can i do
*** cannot find /usr/sbin/setquota. Please make sure that quota is installed (yum install quota) ***
Once requirements are met, run the following to continue the install:
  ./install.sh
This is very strange i have to say
this is why it block...
run
yum install quota
than edit /etc/fstab for /home and / partition and add to them usrquota,grpquota
Then run mount -a and try reinstall :)
Regards
run
yum install quota
Regards
Hehehe where would i be if it were not for you my friend thank you :) that did the trick
this did just slip my eye
